BSC, Insulating Brick Walls
don_52
don_52 Member Posts: 199
Good Morning,
Read this a few days ago, buildingscience.com, thought folks may be interested, or not.
BSD-114: Interior Insulation Retrofits of Load-Bearing Masonry Walls In Cold Climates
Linkage
http://www.buildingscience.com/documents/digests/bsd-114-interior-insulation-retrofits-of-load-bearing-masonry-walls-in-cold-climates
db
FYI, I have no connection with BSC. The point of view
expressed in the article is that of the authors.
  • JJ_4
    JJ_4 Member Posts: 146
    Thank you
    This is an excellent article. I tried and tried to find something like this when I needed to "fir-out" walls for my kitchen (to allow me to run the required electrical circuits). My place is a 1923 grocery store with 3-wythe brick and 1" painted plaster on the interior.
    Since I couldn't find any information I winged it and ended up pretty much as the article describes but with rigid foam instead of spray foam.
    I did leave a 1/4" gap between the foam and wall, which based on the article I shouldn't have, but I'm in Colorado where moisture is not really much of an issue.
    I do plan to make sure that my foundation drainage is good and take a look at the window corners to make sure they drain properly; as the article suggests.
    Thanks again....
