Side Wall Power Venter for a gas boiler
Bfliqezs
Member Posts: 4
Hi does anyone have any experience w/ installing the fields power co. swg 4hd vent kit.
Does anyone know if these are legal on Long Island for an existing, conventional gas boiler,
Thanks,
Mike
Thanks,
Mike
Re Fields, Tjernlund or Exhausto
We have worked on some of the above first 2 over the years, the last one, Exhausto is the best one I have seen. Cast aluminum housing and fan blade. $$$$ although, but I felt worth it. I would think that your area would allow them as ours does. You could also check w/ venter mfr on approvals but I do think you would be allowed. PS, the Fields and Tjernlund are fine but are noisy comparably to the Exhausto. Good luck http://us.exhausto.com/NewSite/casv.htm0
- 167 Indoor-Air Quality
