Thermostatic valve on cast iron radiator
Hello,
I finally found good looking TRVs at a reasonnable price.
Now, I'd like to find the manufacturer of those valves.
The french plumbers can only have "Balmoral" valves now at
outrageous prices. I'd like them to establish a contact with
other manufacturers to get better prices on better looking
valves. This way, they could make a little money by selling
good looking valves at a good price... maybe better than the
price I got for me (remember, I'm a particular).
Anyway, I attached two pictures of the valves. Does anyone
know who makes them?
Thanks in advance.
Bruno Verachten
  • Gounthar Frankfurt
    Gounthar Frankfurt Member Posts: 28
    Hi guys,
    I hope my question won't pollute your forum too much ;-) I'm a french
    private individual, and I found your website a few months ago when
    looking for old cast iron radiators documentation. BTW, bravo for
    these brochures and catalogs, it was a great pleasure for me to read
    them.
    I currently have a less than a year old hot water system at home with
    panel iron radiators.
    I have been fond of cast iron radiators for years, but my wife didn't
    want any (OLD, ugly, pricey...).
    Anyway, I finally found a not too pricey source for patterned cast
    iron radiators, and now have four French Rococco radiators.
    before "restification"
    beginning of "restification"
    I will throw away some iron radiators to install the cast iron
    radiators. We have an electronic thermostat in the living room, and
    the radiators in this room have a simple valve. The thermostat asks
    the gas boiler to heat the water and make the water circulate when the
    temperature it reads is not high enough. The other radiators have
    thermostatic valves, except for the bathroom (always fully opened).
    The cast iron radiators will be installed in rooms where the iron
    radiators had thermostatic valves. The first question I have is :does
    putting a thermostatic valve on a CIR has sense?
    The plumber who installed the system last year told me that the
    inertia of the CIR would make the thermostatic valve useless.
    What do you think of that? I do trust this guy, but he doesn't write
    books about heating, you know? ;-)
    My second question is about thermostatic valves too. I checked
    everywhere I could to find affordable valves with a look that could
    match the beauty of old cast iron radiators, with no luck.
    There are nice simple valves, but the thermostatic valves are most of
    the time really expensive, and ugly. There used to be a thermostatic
    valve called "Chartwell", but vendors seem to not sell it anymore,
    because it didn't work well.
    Even the french manufacturers who produce reproduction CIR don't sell
    thermostatic valves. Do you know where I could find nice thermostatic
    valves for old CIR?
    Thanks in advance, I hope I'm not off topic.
    Bruno Verachten
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Not at all off Topic
    Thermostatic Radiator valves make great sense on cast iron radiators for the very reason that your plumber mentioned--inertia.
    Standing iron radiators have lots of mass and high volume and the TRVs will control the flow effectively turning them into quite large flywheels. In a perfect world where a system is perfectly balanced and you want the entire structure at the same temperature the TRVs won't have much use.
    But, this is an imperfect world filled with imperfect systems and people always have changing desired. The TRVs allow the radiators to compensate for all.
    Regarding "ugly" TRVs: There are period-looking TRVs available in the UK. Very expensive as the pound is high against the dollar. Not sure about your exchange rate. Also unsure if the threading will match as things from the UK tend to have straight (as opposed to tapered) threads.
    Ok. So I do have to find nice TRVs for my radiators.
    I found period-looking TRVs at Tuscan Foundry, but they are hand made,
    and cost more than £200 (290€). I paid less than that for each
    radiator. Anyway, if they are the only period-looking ones, I'll buy
    them, but one by one ;-)
    As for the threading, my radiators have 3/4 threads if I remember
    well.
    Thanks for your answer.
    Bruno Verachten
    Tuscan Foundry
    Sounds like the ones I was thinking of--both name and price...
    Make certain that you verify that the threading is compatible! Would be terrible to pay that kind of price only to strip the threads and/or not get a good seal!
  • ScottMP
    ScottMP Member Posts: 5,882
    Bruno
    SOmetime there is No inexpensive solution to a problem. Quality is expensve and if you have beautifull radiators that you are happy with and the TRV's that you need to make the system work well are costly .. so be it.
    I have no problem with searching for a good deal but a good system will be worth the investment.
    Good Luck
    Scott
    Hi Scott
    Well, TF sells some for 240£, and I found nice looking TRVs
    for £76 (the ones I attached the pictures of in my previous
    post). I don't know if they are good quality, but I think I
    will buy some to see if they suit my needs.
    > I have no
    I agree with you, but I don't want to spend money for things
    outrageously priced. I just don't want to pay more for a
    TRV than for a patterned cast iron radiator... that doesn't
    make sense to me. There is sort of a "niche" for the valves,
    and a lot of vendors make a huge profit (I saw one non
    thermostatic valve at £57, and the same one at £96).
    I don't want to make a bargain at each deal, I just want to
    pay a fair price for good hardware.
    Thanks for your answer, and for reading my ranting ;-)
    Bruno Verachten
  • ScottMP
    Quality
    is priceless !!
    The cost of the valves will long be forgotten when your sitting in a comfortable home and your wife is snuggling warm :).
    Another 40 ( I don't have that pound key ) you probable spend more than that on a good meal and thats forgotten two day later.
    Some things are worth the expense :)
    Scott
    Ok Scott, you got me, I'll have a second look to expensive
    valves ;-)
    But... I still want french plumbers to get contacts with
    period looking valve manufacturers, for them to give us a
    larger choice.
    If anyone has any contact, please share them with me.
    Later,
    Bruno Verachten
  • ScottMP
    Hey
    get the Polish plumber and make the wife happy :)
    lolol
    Good Luck
    Scott
  • thfurnitureguy_4
    thfurnitureguy_4 Member Posts: 398
    OK so I'm a pig, but I couldn't help reading this thread in my best Peter Sellers Voice. Hope it all works out T.
    Hi,
    I'm lost. I finally found a good looking valve at a fair price, and just before ordering it from the UK, the sales
    person tells me the valves have tapered threads.
    You warned me about the UK having straight threads, and I
    need straight threads (well, I tried to plug a fitting with
    straight threads in the radiator, and it went well, so...).
    The sales person told me the valves are imported from
    outside the UK, but I just don't know the name of the
    manufacturer.
    Is there any adaptor that could fit between the valve
    tapered thread and the radiator straight thread?
    I think it's a bad idea, but I just don't know what to do.
    If anyone has a picture of a tapered thread, please add it
    to this topic. As English is not my native language, I
    sometimes don't understand things the way I should :-(
    Thanks.
    Bruno Verachten
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    TRV's
    Bruno, Oventrop makes TRV valve bodies and actuator heads in many colors. The valve and head usually cost under $100.US to contractors. The colored heads are $20. more. I do alot of restoration on antique heating systems, and have even sandblasted the nickel plating from the valve body to "distress" the valve and make it appear old. See the Meeker Mansion restoration on my website. Regards, Paul
    Hi Paul,
    thanks for your reply. I'll have a look at the Oventrop
    valves.
    Concerning the Meeker Mansion restoration, thanks for the
    link, the radiators look really nice. Unfortunately, the pics aren't very big, and I don't have very good eyes. Don't you have bigger pics of the valves installed?
    Best regards,
    Bruno
