Crack o matic
Empire_2
Member Posts: 2,340
I've seen pool heaters like that. Can't remember the brand though.
Mike T.
Mike T.
JE
Is that a Laars JvS?? Probably running too low return temps.0 -
JE
Mike T.0 -
Ouch!
A copper tube boiler without a functioning flow switch!0 -
Not necessarily flow related
Look at the green stuff on the copper. That's looks like low return water temps to me. Plugs up the space between the fins, blocks the flue gases, starts to soot on top of that, and overheats the exchanger.0
- 167 Indoor-Air Quality
