TXV
Techman
Member Posts: 2,143
Mike T ,hows things? The only info on the head is the SAFXAF5 but I will try Sporlan . Thanks!!!!!!!!!!!!!!!
TXV
Does anyone know if a FUJIKOKI TXV is for R22 or R12. The info on the valve is SAFXAF5 and 5FE-1E.Thanks!0 -
Hey Terry
No Ref. stamped on the valve head? Sporlan .com may give you the answer.0 -
Hey Terry
No Ref. stamped on the valve head? Sporlan .com may give you the answer. Is there any brand name on it to cross reff.?0
