Ph Tester
Ron Schroeder_3
Member Posts: 254
by using pH strips and a comparison chart.
If you want to dazzle your client then purchase an inexpensive pH pencil at your nearest full feature hydroponic growing supplier.
Ph Tester
Looking for recommendation on purchase of a digital Ph tester, for aluminum heat exchangers. Durable but not too exp. $100-200.
George at Rhomar sold me mine
I use it all the time. Simple to use and within your price range. Visit rhomarwater.com
Water quality is an issue we all should be paying far closer attention to when it comes to hydronic systems. Do you have a pH issue?
Wallace Radiant Design
No problem
Just want extra peace of mind, ph & chlorine strips are more likly to be damage/loss on shelving then a tester would be.
Thanks, will look at rhomarwater.
Hach
is a great brand. Mine came from Rhomar also. Find Hach in the Graingers catalog.
hot rod
- 167 Indoor-Air Quality
