Trap x-reference
Timco
Member Posts: 3,040
Can anyone tell me what x-references to Dunham #1 and #1E traps? Maybe Mcdonnel or B&G?
Tim
Tim
Just a guy running some pipes.
The 1E is still made
go here:
http://www.mepcollc.com/thermost.htm#Mepco2
The Barnes & Jones #122 has a similar throughput.....
www.barnesandjones.com
Is the 1E the newer version of the #1? Both seemend identical and would interchange, but the #1 had a larger diameter disc in the middle.
Thanks, TimJust a guy running some pipes.0 -
Yes it is
the #1 has gone thru versions 1A thru 1E I believe.
If you have a bunch of #1 thru 1E traps you can get replacement innards from MEPCO (which absorbed Dunham), Tunstall or Barnes & Jones.
I have a mepco dealer right here in town and will try them first. BTW, where does a midget trap fall into the evolution of the trap?
\"Midget trap\"?
That's a new one on me. How about a pic? Do you know who made it?
Here she is...came out of that Brigham City job...
Never seen one
doesn't appear in the 1922 Dunham Handbook- are there any numbers on the body?
last pat date is 1911. not a mark on the body. I have a few of these I saved from the trash can. Stamped on the brass of the cap just under the word Iowa is either B377 or R377...that is the only mark.
Tunstall has it in their x-ref
http://www.tunstall-inc.com/seven/frame/dunham.html
B&J doesn't, unless it's listed as something else.
- 167 Indoor-Air Quality
