Energy Codes
Steve_101
Member Posts: 1
A local code enforcement officer is requiring that we insulate an existing ductwork system on a boiler repacement we are doing on a hydroair system. The customer doesn't want to/can't afford to, insulate the existing ductwork. If we don't do the ductwork he won't pass the work. Is he misinterpreting the code? I don't have a copy.
your permit
should be for the boiler only and doesn't include pre-existing conditions on other portions of the system unless you're altering/remodeling that portion as well. Exceptions would be for something that creates a known hazard by virtue of its existing installation. On the other hand, your customer may well be interested in the energy savings the insulation will bring.
The new state-wide code in PA has a few very large loopholes in it - a few glaring flaws really. If we are installing a heating or air conditioning appliance and don't alter its size (BTU wise) or fuel - we don't need a permit or an inspection! Same goes for plumbing fixtures if we don't alter their original location. Go figure.
On the other hand, if you do a heat loss/gain calc and determine the appliance BTU size needs altering, then you need to provide a Manual-J calc, pick up a permit and schedule an inspection.
Guess which method will be picked?!?
Rewarding laziness
and incompetance doesn't seem to be heading things in the right direction. Down here they make it so hard to get a gasfitters license that a lot of contractors go without and don't pull permits. I have to hire a plumber friend to pull my permits for furnace and boiler changouts since I'm HVAC. I'm pretty sure I could pass a gasfitters test since I've been teachng it in trade school for several decades now. Don't get me started. There oughta be a better way. WW
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
