what boiler 75000 btu has a 4\" vent/San Francisco
ALH_4
ALH_4 Member Posts: 1,790
The <a href="http://www.triangletube.com/CondensingBoilers/PrestigeSpec.htm"target="_blank">Triangle Tube Prestige Solo 110</a> has a 3" vent.
  • doug o'connor
    doug o'connor Member Posts: 17
    what boiler (75000 btu) has a 4\" vent
    I have a double wall 4" vent installed. thought i ask if there was a boiler to fit this or do I have to bring in a new vent. I have a 7" x 8" shaft for the vent but I need 1" clearance. vent is going up to roof. about a 18' run.
    DOES ANY ONE KNOW OF A BOILER WITH A 4" VENT?
  • doug o'connor
    hot water radiater
    the heating system is hot water radiater.I need a boiler with hot water.
  • tim smith
    tim smith Member Posts: 2,861
    Yes on the Solo
    You only need .25" air space around the vent. Solid reliable product. Good Luck. Tim
