what boiler 75000 btu has a 4\" vent/San Francisco
ALH_4
Member Posts: 1,790
The <a href="http://www.triangletube.com/CondensingBoilers/PrestigeSpec.htm"target="_blank">Triangle Tube Prestige Solo 110</a> has a 3" vent.
what boiler (75000 btu) has a 4\" vent
I have a double wall 4" vent installed. thought i ask if there was a boiler to fit this or do I have to bring in a new vent. I have a 7" x 8" shaft for the vent but I need 1" clearance. vent is going up to roof. about a 18' run.
DOES ANY ONE KNOW OF A BOILER WITH A 4" VENT?0 -
hot water radiater
the heating system is hot water radiater.I need a boiler with hot water.0 -
Yes on the Solo
You only need .25" air space around the vent. Solid reliable product. Good Luck. Tim0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
