different size pex's
SWS2_3
SWS2_3 Member Posts: 3
Anyone have any experiennce with mixing tubing sizes on the same manifold? Looking at a few 5/16" for quik-trac and a few 1/2" for an undrfloor area. Better off with 2 manifolds / circs??
  • I would think it would be tough to balance, but if you do the math and you're careful with loop lengths.. and have balancing valves... it should be doable.
  • RoosterBoy
    RoosterBoy Member Posts: 459
    well *~/:) funny you should ask :
    did you think of using some 3/8ths and the 5/16ths ? they are a bit more closely related.
