Indirect Water Heater
Alan(OnVacationInOregon)Forbes
Member Posts: 232
the boiler..........If it continues to flow with pressure, you've got a bad HX.
What's The Best Way To Check If The Coil In An Indirect Water Heater Is Leaking Causing The Boiler Pressure To Rise?
Can You Isolate The Tank From The Boiler With Valves And Check Pressure With Gage? Do You Need To Do This With Cold Tank?0
