Find the problem's with this install
tim smith
Member Posts: 2,859
Love the way the S&Rs will flow to those zones, have fun.
Repipe this job and why ?
I went out to look at this install on sat. morning and this is what i stumbled into .I found to many problem's to list can you find some obvious one's.
Will be doing a complete repipe & control design starting on monday .What were they thinking.0 -
Well
For one
The return and supply seem to be on the same header with out P/S
close spaced tees.
He also has pump before tempering valve.
The Fire extinguisher is too small.
I do like that he used just about every single pump manufacturer in N/A : )
for one thing
they shoulda painted the plywood to class up the place a little. Can I get some of those pumps when yer done?0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 970 Plumbing
- 386 Solar
- 17 Recall Announcements
