flow meters and water too clean?
GW
Member Posts: 5,136
I'd like to buy an electronic flow meter. It seems like an affordable model wants the water with: 100 ppm of 100 Microns in Size of Suspended Particulars or Bubbles Required
Does the typical hydronic heating system has enough stuff in it so the device would read the flow?
Thanks,
Gary
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=368&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Thanks,
Gary
You can buy an electric hour meter and monitor the circ for far less and much easier if it would work for you...Just a guy running some pipes.0
