Radiantec
RDB
Member Posts: 7
I'm about to build a 32'x26' garage and would like to install radiant heat in the concrete floor. I'd like to keep the winter temp around 45 degrees, and occasionaly up that to 65 or so to work on some projects. Would the Radiantec closed loop system work OK in this appliaction? Can I install a gas fired hot water heater in a garage if it's enclosed in a fire proof enclosure? I live in NY state, or do I have to put the water heater outside in some type of enclosure? I've read some negative comments about this company on The Wall, but that seems to be amied at the Open Loop system. I'd be installing a Closed Loop system. I'm a novice in this area and could use some suggestions. Thanks RDB
why don't
you work w/ a local contractor...that way you can get the hands on expertise, do some of the sweat work , save money and get top notch materials...kpc
- 62 Biomass
