Indirect Water heater
Jim_109
Member Posts: 45
How can I compute the specs for an indirect hot water heater? Regardless of the manufacturer, all the indirect specs are based on much larger boilers than mine.
For example according to a manufacturers literature with a boiler output of 112,000 the 40 gallon indirect has;
the 1st hour rating of: 180 gallons
continous flow of: 150 gallons
Peak flow gallons per 10/minutes: 50
The numbers above are based on 200 degree water temp and 90 degree temperature rise.
What numbers can I expect with my Net I.B.R. Output (MBH)3 pass boiler is 58,000
it all depends on...
the heater...coils transfer at diff. rates... go to htproducts.com and look at there instal manuals. On the front page they have different rates for boiler outputs. kpc
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
