Help for replacing mains vents (w/ fast venting valves)
Hello,
I have recently purchased a home that uses an older steam furnace for heat. My father said that if I posted here someone would be able to help me figure out what size vents are needed to replace the older main vents with fast venting valves. Here are the measurements for the mains (there are 3 loops).
Loop 1: 18 feet of 2.5 inch diameter pipe, then 17 feet of 2 inch pipe (return) before reaching the current vent.
Loop 2: 46 feet of 2.5 inch diameter pipe, then 29 feet of 2 inch pipe (return) before reaching the current vent.
Loop 3: 28 feet of 2.5 inch diameter pipe, then 15 feet of 2 inch pipe (return) before reaching the current vent.
After each of the the current vents, there are about 6 feet of pipe for each loop that connects it back to the (natural gas fired) boiler. I am assuming that the length after the vent isn't as important as the rest of the loop.
Another question that I have is, it seems sort of "time consuming" to put the vents all the way back by the furnace when pushing the steam out. Would it be beneficial to retap the mains and put them after the last radiator? I do not plan to do this at the moment, but if it is something that would be beneficial, I would consider it.
If any additional info is needed, then please let me know and I will get it for you. I greatly appreciate any help and suggestions that people can provide.
-Beaty
