Knight wall mount
bigwilly104
bigwilly104 Member Posts: 50
So is the Knight wall mount avalable now. Has anyone used it. After my last install I decided to switch from munchkin to the knight. I havent used one yet though I have three new construction jobs that are not at that point yet. I just looked at a change out today and am putting together the bid. I went to the lochinvar site to get the link for the Knight brochure. I see wall mount coming soon on everything that would be great for this job. ALso the pump that they supply is a Taco I think but its steel. Around here the hard water eats your lunch if you use steel. I wont use anything but bronse or stainless pumps so I guess I will have to buy a stainless Taco to replace the supplied pump.
  • tom_49
    tom_49 Member Posts: 267
    I was talking w/ the local rep. last week. I think they are available but not approved in Mass. yet. Where are you located?
    I like the Knights as well. We have about 12 installed ,no problems.
    tom
  • Stirling Boston
    Stirling Boston Member Posts: 33
    Knight Wall Mount availablilty
    They go into production the first of October. If you want to get an up close look, there is one at the radiant house at the RPA show.
    Thanks for the support.
    Stirling
