beckett NX with Buderus g115/28
JAtch_2
JAtch_2 Member Posts: 2
We are in the process of installing a buderus 115/28 with radiators to replace a forced hot air system. The vent will be to the current chimney.
I was expecting the unit to come to with a Riello but now that it's on site, I saw today that it has a Beckett AFG. I decided to check on the web before discussing this with my heating contractor, and after that reading, I think that I would to use the Beckett NX, both because it seems to be well designed and it seems to offer the flexibility of going to a direct vent in the future.
Does this change make sense? Also, has anyone had any experience with the Beckett Heatmanager unit? I seems like interesting technology. thanks for your thoughts...
  • RoosterBoy
    RoosterBoy Member Posts: 459
    if i was you id see if you could get the riello burner for your buderus it's a real nice burner and it's quite. i cant even here mine come on.
    also riello is a tricky burner so just make sure who ever will service you can work on riello
    also don't direct vent unless you really have no other choice. if you get lot's of wind or you go on vacation in the winter you could have burner lock out problems. with direct vent
    keep the chimney and if you ever have to dump it just get a power venter it has more power to blow the gas's of combustion out.
    as far as heat manager id go with the buderus heat manager they call it the r2107 out door reset http://www.buderus.net
    good luck and post your new install pictures when it's done
