Paging Bill @ Honeywell (Steamhead)
Steamhead (in transit)
Member Posts: 6,688
Bill, I need to know if this sensor is still available. We're working on a Honeywell/Centra outdoor reset/timer on a steam system, and someone decided a pressuretrol on the main header was an acceptable substitute. I've been told the Centra is no longer in production, but the unit appears OK otherwise so we're looking at installing the proper "steam-establishment" sensor.
Thanks!
Thanks!
Unfortunately, the Centra is kaput...
That was a great system, but we don't make them anymore.
The T775 series of light commercial temperature controls migt help, they work with the new direct-coupled actuators and steam valves. Those are restricted items, you'll need to contact a Honeywell Commercial distributor.0 -
I'll dig around in the
control spare parts section. Might have a scavenged VF20. Will let you know.
Thanks again, Ron
nm0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
