DOE's latest energy outlook
Doc Radiant
Doc Radiant Member Posts: 57
  • Noel Kelly_3
    Noel Kelly_3 Member Posts: 43
    http://www.eia.doe.gov/emeu/steo/pub/contents.html
    The upside is that this could be used as a sales tool.
    Noel Kelly
  • Constantin
    Constantin Member Posts: 3,796
    Absolutely right....
    ... this forecast, along with the many testimonials we have had from delighted customers re: energy savings, should be required reading for any homeowner dithering on whether to install a condensing gas boiler or not. I'd print the thing and hand it out with every proposal.
    And to think that when I was involved with the DoE to set energy efficiency standards for AC, etc. that the prognosis in 1999 predicted energy prices would be falling 10% from 2000-2005, IIRC...
  • S Ebels
    S Ebels Member Posts: 2,322
    That is a highly informative report
    Very sobering. It should be mandatory reading for everyone involved in the HVAC trade. Consumers who are comtemplating new construction, remodeling, HVAC system updates etc should be made aware of these numbers. I have a set of plans drawn up for a new house we hope to build someday. I think I'm going to scale back the sq footage and upgrade the insulation as much as possible.
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    And once that (scaling back size while increasing insulation) is done, there will be ever more call for condensing/modulating boilers with significantly lower outputs than currently available!
  • jerry scharf_3
    jerry scharf_3 Member Posts: 419
    Amen
    says the choir.
    Best I have heard of so far is a British unit mentioned on the wall that modulated down to 8 MBH, IIRC.
    jerry
  • Noel Kelly_3
    Doc!
    Hey Jim - long time!
    You still with SF - and is that your picture on the radiant page?
    Drop me an email at endykaye@go.com and I will bring you up to date.
    Noel
