Suggestions on removing paint, then repainting steam radiators
Mike T., Swampeast MO
Member Posts: 6,928
I've had very good success using a pressure washer with a zero degree (rotating) nozzle. Won't say that it removes every last bit of paint, but it gets the vast majority and whatever is left is <I>very</I> well-adhered.
In most cases there's little if any paint deep inside as it takes an angled brush and lots of patience and time to completely coat a radiator. Other than the original coating (which sometimes covers the entire radiator), later coats are usually "just where a straight brush can reach".
No need for special "high temperature" paint--just NEVER use latex over bare iron! After a coat or two of oil-based primer you can switch to latex, but from then on ONLY latex can be used.
How do I remove paint, then repaint steam radiators?
Hi, after disconnecting and dragging them outdoors, what�s the best way to remove all the paint from steam radiators? Will a power washer do the job? Home Depot doesn't rent sand blasters
. How the heck do you get to remove the paint between the tubes? I have health concerns as I have several small children and the paint is chipping and I want to learn how to strip and repaint them. If anyone can also recommend a safe paint for steam radiators (& suggestions as how many coats to use, if primer is needed, etc., my little gremlins and I would appreciate it. Thanks! 0 -
paint removal on rads
Do a search on this topic & check the library. Recent photos & discussion of using a pressure washer.
I called around & found an industrial paint contractor who did a beautiful job (sandblasting) for what I feel was a fair price. The radiators look like they were just manufactured yesterday (they're 1920's Corto's).
I had him prime the rads with a high quality solvent-based primer. I'll spray finishing coats on myself, although I may see what he would charge for the next batch.
It took a bit of search (some sandblasters didn't want to bother, others didn't seem to think they could do it). The only real issue was geting the beasts out the door & into the truck (and then back again). They're like cats - they don't always obey when you order them out the door & up the ramp. It's the 5 or 6 footers that scare me - these 3 or 4 foot rads are only about a 1/4 ton each - a piece of cake.
Good luck.0 -
my thought
I have a monuments maker (tombstones) that will sandblast Rads if brought to him. I then take the sandblasted Rad to the Auto body shop and have them paint em up. Best Wishes J.Lockard0 -
On the "Resources" tab at the top banner, go to "Hot Tech Topics". Then look for three articles titled, "Stripping Radiators", "Painting Radiators" and "Bronzing Radiators".
- 167 Indoor-Air Quality
