Cast Iron Radiators Free!!!
John Van Hoesen
Member Posts: 91
Hi Steve -
THanks for the offer, I could pick them up this coming Sunday, but not any earlier. So if someone can't get there before me, I'd love to take them off your hands. :)
THanks again and just let me know if you'll be around. Thank so much!!!! My email is jgv@unlv.nevada.edu drop me a note and I'll email you my number to work out the details if it's convenient.
cheers
John
cheers
John
2 small radiators
I have 2 small radiators that I took to the curb but brought back because someone might need them. They are in the West West Hartford, CT area. Free post flood pickup is coming so speak up quickly if you want to pick them up.
Post your email if interested and I will contact you.
Steve0 -
Free radiators???
Steve,
I hope I am getting to you quickly enough. I am doing a new room and found this site because I have questions on cats iron vs baseboard. Im questionig if I should use my cast iron ones because 1) I need to do some framing of a header to install, and 2) I have the type that recesses into the wall and Im not sure of heat loss/efficiency since they will go on outside walls.
I saw your post and I am interested in your radiators. They may just do the trick for me. Im not in CT - Im in NY but I do get to CT from time to time (for relatives) and parentw will be moving there very soon as well.
If you can hold them a bit longer, Im interested, and we can arrange something.
Please email me at rkoudelka@yahoo.com. I wouldnt be able to get them right away, so if you dont want to hold them, I understand. But let me know.
Thanks,
Rich
radiators
Steve,
I am not far from you (Torrington), but unfortunately I did not see your post first! If it turns out they are still available, I could pick them up anytime. Thanks.
John
P.S. My email is jdilauro@snet.net0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
