Which boiler for Radiant & Base board system
Weezbo
Weezbo Member Posts: 6,231
  • andy_16
    andy_16 Member Posts: 12
    boiler for radiant & baseboard system
    Renovating a 3000 sq' home on Long Island NY. need a Gas fired direct vent boiler. Radiant heat 1 st. floor & baseboard heat 2 nd floor & hot water coils installed on a/c unit in attic for back up on radiant. would also like w/ a hot water storage tank. was recomended the Dunkirk Quantum 90 for a boiler,& Burnhum. anyone w/ experience w/ these units. I was suprised by the aluminum heat transfer plates on Dunkirk,are these long term, would antifreeze in system cause problems. Should I also be looking for a modulating system ? Can I expect reliable service if there are problems? Any in put would be appreciated.
