Dan's latest newsletter
ross_5
Member Posts: 19
I was just reading the piece about 3 sales models in Dan's latest newsletter. I am questioning the guy selling only condensing boilers. If you are going into an old system (you know, 180 F supply, 20 degree delta T), are you ever going to be in condensing mode to get those higher advertised efficiencies? Are there other advantages to those units that I'm not seeing here?
It depends
but in most systems you'd be surprised how often it does condense
condensing boilers
> it does condense_A
> HREF="http://www.heatinghelp.com/getListed.cfm?id=
> 313&Step=30"_To Learn More About This
> "Find A Professional"_/A_
Are you talking about part load conditions? I've wondered whether a condensing boiler could be justified for an existing old style system just based on the part load condensing situations.0 -
Yep
Outdoor reset and burner modulation are both very important. Design temperatures are just that moment in time that we design for. The vast majority of the time, outdoor reset keeps the boiler at lower temperatures. Also, mod/cons are more efficient at lower modulation.0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 970 Plumbing
- 386 Solar
