High velocity ducting of pool dehumidifier
Empire_2
Member Posts: 2,340
Usually with pool environments if you dehumidify, you will often end up reheating the structor. Dectron uses heat rejection and heat recovery in the same unit. If you need to dehumidify, why reject the heat to the outside? That is why they are so expensive. I'm sure you want to prevent the water from dripping down the walls or there will be hell to pay by the customer. Indor air has to be warmer than the water at about 50 to 55%RH.
Looking for input as to indoor pool dehumidification with Unico or Space-pak. Looked into Desert-Aire among others and was floored by price. Would like to use Unico throughout or at least their slot defusors for asthetic concerns.0 -
Try an HRV
Lifebreath sells reasonably priced pool HRV's that do not take a lot of maint. Work well to remove the humidity and recoup the heat at about 78% eff.0 -
Lifebreath.
John is on it. Quite a few variables to consider, but if all the numbers work, quite an inexpensive alternative to expensive pool dehumidification units.
J0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
