Digital Temperature Sensor Failure
Joe Sackett
Member Posts: 1
In August 2004 my heating conractor installed a new System 2000 model Ek1 Oil burner and Hot water storage tank.
I've had to replace the Digital Temperature Sensor in August 2005 and July 2007.
The Heating Proffessionals serving my hometown are clueless
as to why.
I'm hoping for a helpful hint so we have something to troubleshoot at my next tune up.
as to why.
sensor trouble
Not a fan of System 2000, but it sounds like an electrical error somewhere in the system. Get in touch with the local factory rep. That's what they are there for. If this is a reoccuring problem, there may be some history of other like problems. He should be able to help you and your heat guy solve the problem0
- 167 Indoor-Air Quality
