Residential Steam Heat Help in Albany, NY
Brad White
Member Posts: 2,399
Smart choice. You bet!
"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad
Plumbing Help Needed
Can someone recommend a steam heat expert in the Albany, NY area? Now that I have read Dan's books, it is clear that I need to make some changes to my boiler, which is plumbed to the existing system in copper (a real no-no as I understand it). I don't have the tools to thread 3 and 4 inch lines.
Thanks
Rex0 -
Thermal Perfection
Darin @ Thermal Perfection. He advertizes on this site. He's the best! Lives in your area...
Rick0 -
Residential Steam Heat in southeastern NH
I have been told that I need to replace the 20 year old steam boiler in my home. Can anyone recommend the real steam expert(s) in my area...southeastern New Hampshire. Thank you.
JDK0
- 120 Geothermal
