Problem in \"The Library\"
No problem. I wasn't sure if it was just my computer or something else.
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    I went to "The Library" to see if that's where I'd seen the picture of the dining room rad I just bought. Many of the links are now missing. Titles there, but no way to access the info.
  • bobbyg_2
    bobbyg_2 Member Posts: 139
    I see the same thing. I think the titles were once hyperlinks to the document. Now they aren't???
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    The site
    is going through some changes this afternoon. Everything is being moved around. Thanks for your patience.
    Retired and loving it.
  • somebody
    somebody Member Posts: 22
    the Library
    Please try that now....
    Yes, the PDFs are back.
  • invision
    invision Member Posts: 25
    Please check
    Everything should be back but please let Dan know if you notice that something seems weird or missing.
  • invision
    Please check
  • invision
    re: Please check
    > missing.
    Everything should be back up. Please let Dan know if you notice that something is not working right...
  • invision
    re: Please check
  • invision
    re: Please check
  • invision
    re: This is a check
    > right...
    Check for functionality of Enter
  • invision
    re: This is a check
    > right...
    right...
  • invision
    re: This is a check
    > right...
    check for functionality
  • somebody
    re: function check
    > right...
    function check
  • invision
    > right...
  • invision
    Please check
    > right...
    Please check
  • invision
    re: This is a check
    > right...
    This is a check
  • invision
    please check
    > right...
    please check
