Problem in \"The Library\"
Mike T., Swampeast MO
Member Posts: 6,928
No problem. I wasn't sure if it was just my computer or something else.
I went to "The Library" to see if that's where I'd seen the picture of the dining room rad I just bought. Many of the links are now missing. Titles there, but no way to access the info.
I see the same thing. I think the titles were once hyperlinks to the document. Now they aren't???0 -
The site
is going through some changes this afternoon. Everything is being moved around. Thanks for your patience.Retired and loving it.0 -
the Library
Please try that now....0 -
Yes, the PDFs are back.0 -
Please check
Everything should be back but please let Dan know if you notice that something seems weird or missing.
Please check
re: Please check
> missing.
Everything should be back up. Please let Dan know if you notice that something is not working right...
re: Please check
re: Please check
re: This is a check
> right...
Check for functionality of Enter0 -
re: This is a check
> right...
right...
re: This is a check
> right...
check for functionality0 -
re: function check
> right...
function check0 -
> right...
Please check
> right...
Please check0 -
re: This is a check
> right...
This is a check0 -
please check
> right...
please check0
- 167 Indoor-Air Quality
