Visio Stencils
Simply Rad_2
Member Posts: 171
I have had Visio 2003 for a few years and I am in need of some more stencils. I have Taco and Tekmar but I need more of the basic drain, water feed/back flow. Any ideas
Jeffrey
Jeffrey
Visio
These symbols are based on ANSI/ASHRAE Standard 134-2005, STANDARD Graphic Symbols for Heating, Ventilating, Air-Conditioning, and Refrigerating Systems so they lack the graphic artist flair...go here Radiant Based HVAC Symbols ...open the file up...and let me know which symbols you want and I'll send them to you.
rb0 -
Visio Stencils
RB
I can not quit make out the stencils they are too small of print. Can you increase the attachment size. I am interested.
Thanks Jeffrey0 -
reposted
...a little bigger.
original size is 17 x 11
Best is to use the link for a full screen size view.
Cheers,
RB0 -
Tech Services
Contact tech if you are interested in some of our stuff. 952-997-7900
Tim D.0
- 86.8K THE MAIN WALL
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
