vapor system short cycling
Steamhead (in transit)
Member Posts: 6,688
the boiler's output may still be a bit more than the radiation you have. Try down-firing just a bit.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
short cycling on pressure
I installed a new boiler on a 2 pipe vapor system. There was a hoffman loop which I took out and installed a Gorton # 2 and two Gorton # 1's. One main is 66 feet long 2 1/2 ". And one main is about 75 feet 2". The vaporstat is set to cut out at 12 oz. and the diff is set at 6. I got a call today that once everything gets hot it will short cycle on pressure. On for 30 sec then off on pressure. What should it be set at? I waas going to set the cut out at 14OZ and the diff at 12OZ. Would that cure the problem or Do I need more venting? THanks.0 -
If everything is hot when it starts to short-cycle
then all the air is out. Maybe the firing rate is a bit too high.
I measured all of the radiation
and sized te boiler properly by the EDR. It's a gas boiler. If I set it up with a wider differential would that make it stay on and off longer?0 -
Or ...
> bit.
> _A
> 367&Step=30"_To Learn More About This
> "Find A Professional"_/A_
Or ...
If it is a orifice type vapor system, then you need to mulitply your calculated EDR by .8 to arrive at the EDR the boiler actually sees.
Boilerpro0 -
Or ...
Boilerpro0 -
Are you sure you cleaned it enough?
Mad Dog
probably not
I probably didn't clean it enough because it was getting late and I am going back for an inspection anyway. I skimmed it and replaced all of the wet returns. Hopefully thats it. I'm going back tommorow and i'll skim some more.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
