GB-142 condensate filling question?
Joe@buderus_2
Member Posts: 302
I would suggest filling the condesate trap by pouring 1 quart of water down the exhaust pipe. Please keep im mind that if the GB142 is used for an all high temperature application anti freeze should be added to the condensate trap to prevent evaporation. It is not recommended to add the anti freeze through the exhaust pipe.
How do you fill the inner condensate tank on the GB-142? One manual I have says to remove it and fill it (which seems impossible, being that it appears to be molded on the top) and another application manual says to pour 1 qt. of water down the exhaust pipe-what do you guys do?0 -
fill
I carefully disconnect the trap, and fill it up with a water bottle....But if it ends up in the trap by pouring down the stack.Thats the way I will do it on the next one..0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 962 Plumbing
- 385 Solar
- 15.3K Strictly Steam
