boiler encased in concrete
M Knopp
M Knopp Member Posts: 2
Can you settle a bet?
See the two photos, which show identical hot-water boilers in a gravity system, circa 1910, in a three-story duplex. The radiators they serve are identical:
Boiler 1 serves the first floor and one radiator on the third floor.
Boiler 2 serves the second floor and one radiator on the third floor.
While the boilers are identical, the one serving the second floor (Boiler 2) is encased in a foot or more of concrete.
Why?
I say it was installed as a heat sink so that the resident on the second floor wasn't giving free, stray heat to his neighbor downstairs. Boiler 1 wouldn't require the concrete jacket, since any stray heat would rise and heat the first floor anyway.
A colleague says Boiler 2 was given the jacket as insurance because it served the second floor and was thus subject to greater pressure.
Now, this guy is a mechanical engineer, but I can't believe Boiler 1 and Boiler 2 see much difference in pressure. Both serve a radiator on the third floor, and the gauges don't show much difference in pressure during operation.
Whaddya think? What is the function of the concrete?
--Matt
  • M Knopp
    why the concrete?
    Why?
    A colleague says Boiler 2 was given the jacket as insurance because it served the second floor and was subject to greater pressure.
    Now, this guy is a mechanical engineer, but I can't believe Boiler 1 and Boiler 2 see much difference in pressure. Both serve a radiator on the third floor, and the gauges don't show a no difference in pressure during operation.
    --Matt
  • Bob W._3
    Bob W._3 Member Posts: 561
    But wouldn't the concrete heat sink just give off heat in the basement anyway, thereby heating the 1st floor?
  • mark  smith
    mark smith Member Posts: 112
    that's Too funny ...
    who knows what some moron thought 50 years ago ..
    you haven;t listed any valid reasons ..
    HEY ....maybe it's in case......she blows ...!!
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    My only guess is that with two boilers in the basement that the basement overheated (or was expected to overheat) and the very thick concrete was used as rather strange form of insulation. At a foot thick it does have some insulation value and it's certainly permanent...
  • Todd_12
    Todd_12 Member Posts: 55
    Concrete
    To give Ron a challenge when he replaces it?
  • bob_50
    bob_50 Member Posts: 306
    Mark Eatherton's
    dad installed it. It was an experiment in radiant thermal transgression. :>) bob
  • Eugene Silberstein 3
    Eugene Silberstein 3 Member Posts: 1,380
    Actually, it was the boiler...
    You see... the boiler had an inferiority complex and was very upset at the thought that, at some point in the future, it would be ripped out and replaced with a newer, more effient model.
    So, in an effort to remain installed, it decided to build the wall around itself, in a manner similar to a moat around the castle, to prevent those from penetrating its walls.
    And, from the looks of things, the wall concept has worked.
    Oh my G**! I'm starting to sound like Weezbo.
  • Weezbo
    Weezbo Member Posts: 6,231
    It is an ancient practise of the Mongolians...
    you incase the heating system in the cement and then everyone sleeps on it to keep warm through out the night...only thing though these musta been Vampire Mongolians as there is only room for people who can hang from thier feet:)
  • Mitch_4
    Mitch_4 Member Posts: 955
    where's the
    little boiler that built its wall of straw, and the one of stick...should be a round there someplace..
    Mitch
  • That'd be my guess...
    Radiant Shield. THink about it. When you walk down into the basement to stoke that puppy, what sensation do you feel. RADIANT ENERGY glowing from the SOURCE. In an attempt to control the beast, they built a massive wall around it. I'd guess that they were soundly defeated in short order...
    ME
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Milne often.....
    Tells the story of the Steam Shovel but the name escapes me.
    Maybe someone read it and thought it was a good idea ? Happy T-Day Chris
  • tonypete
    tonypete Member Posts: 24
    The steam shovel's name was
    MaryAnn. Mike Mulligan was her operator.
  • Timco
    Timco Member Posts: 3,040
    Maam...for just an extra $49.95, we will add a insulation layer around the boiler saving you hundreds on your next season's coal bill!!!
    Just a guy running some pipes.
  • jeff_51
    jeff_51 Member Posts: 545
    personally, I think mitch got it right
  • ScottMP
    ScottMP Member Posts: 5,882
    My Guess
    is the house was owned by an engineer who thought he knew more than his heating contractor .... nah that never happens.
    Its Maryanne and Mike has just gone to get some more pie from Mrs Magilicuddy.
    Scott
