Steamhead - Forgot to ask you...
Steamhead (in transit)
Member Posts: 6,688
and there's only one vent per street ell, you should be OK.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Main Vent Question...
I got booted before I could ask you if it makes sense to put the 3 Gortons on a 3/4 cross with street 90's. I've read other posts about using regular 90's, does it make that much of a difference when you're putting them on a cross or just on a T? My idea was to put a street 90 on either side of the cross, mount a Gorton on each side and on on the top. Just curious if makes that much of a difference if I use two regular 90's. OR if there is a better configuration, I have plenty of room where the main vents are located.
Thanks again and sorry I couldn't ask earlier...
cheers
JOhn0
- 167 Indoor-Air Quality
