Monoflo tees
Mitch_4
Member Posts: 955
and the system has monoflo tees in it. Never had one before as hydronics is a new avenue for me. I want to make sure the pump is correct as the old one is shot. I cross referenced it to the equivalent Grundfos, but am curious as to how these tees affect the pumping requirements in a system.
Are the additional factors to consider, how do calculate if I cannot cross reference.
Thanks for any information.
Mitch
Mitch
If this is for a modcon...
If this is for a modcon and the customer wants to minimize fuel consumption, you may want to consider repiping to get rid of them - ideally homerun. I say that because those diverter tees will likely cost at least 10°F in higher return temperatures to the boiler and that will affect efficiency. This is because monoflo systems have such high flow requirements that they dilute the branch's ΔT. With a conventional boiler, this works for you, with a modcon it works against you.
Low head, high flow is how these systems operate. I have yet to see a Cv rating for an "open" diverter tee, so I really wonder how people do calculate these.
3 speeds make it easy, use the slowest speed that still heats all the branches uniformly.0 -
thanks
> against you.
> 3 speeds make
No the upgrade will not be a mod con..tried, but they have a very limited budget..small home, CI atmospheric.
Low head and high flow is what I am looking for, are the references or formulae for these?
Removing them will not be done...they can barely afford the boiler, and I am cutting my line to do it or they freeze this winter...both were "downsized" from a factory that cut its force 70%, doing what I can..
thanks
My limited experience...
I had a B&G Series 100 on my monoflo system - 1.25" main with approx. 15 0.75" dia. branches leading to fintube HWBB. Calc'd heatloss was 57K, boiler was 0.65gph with pretty low efficiency.
I replaced it with a 15-58. Worked perfect on speed 2, speed 1 could probably work on a small enough system, but not all branches got heat on mine, particularly the upstairs. In the spring when only the basement and lower rooms are chilled speed 1 actually does the trick...
The 15-58 or something similar should be a pretty safe bet.0
