Bryant 367
I Need a new hot air furnace and air unit. Any advice on picking a brand? One heat guy suggested a bryant 367 ran-105 furnace with a bryant 123 ANA 336 13 seer 3 ton puron condenser. any thoughts?
Mike
  • tim smith
    tim smith Member Posts: 2,928
    Bryant/Carrier, good equipment
    Bryant and Carrier are the one in the same in res. market. Good equipment. Not sure of the Bryant #s that correlate to the Carrier but consider 2 stage furnace w/ maybe ECM variable speed blower. 2 stage at least. Good luck, Tim
  • John Mills_5
    John Mills_5 Member Posts: 952
    They make
    a 2 stage oil burner?
  • Bruce Stevens
    Bruce Stevens Member Posts: 133
    I know Riello
    makes one and is installed in a Thermopride.
  • John Mills_5
    Bryant
    hadn't seen it on them but Riello aren't sold around here. For that matter, few oil furnaces are sold around here!!!!!
  • Tony_23
    Tony_23 Member Posts: 1,033
    367 RAN
    Good furnace. Make sure he has Riello parts and training, otherwise get the 367 w/ the Beckett burner.
    The 123ANA036000 is a good value. Minimum eff. w/10 yr compressor, sound blanket on compressor, low & high pressure cutouts, and louvered coil guard.
