Bryant 367
[Deleted User]
I Need a new hot air furnace and air unit. Any advice on picking a brand? One heat guy suggested a bryant 367 ran-105 furnace with a bryant 123 ANA 336 13 seer 3 ton puron condenser. any thoughts?
Mike
Mike
Bryant/Carrier, good equipment
Bryant and Carrier are the one in the same in res. market. Good equipment. Not sure of the Bryant #s that correlate to the Carrier but consider 2 stage furnace w/ maybe ECM variable speed blower. 2 stage at least. Good luck, Tim0 -
They make
a 2 stage oil burner?0 -
I know Riello
makes one and is installed in a Thermopride.0 -
Bryant
hadn't seen it on them but Riello aren't sold around here. For that matter, few oil furnaces are sold around here!!!!!0 -
367 RAN
Good furnace. Make sure he has Riello parts and training, otherwise get the 367 w/ the Beckett burner.
The 123ANA036000 is a good value. Minimum eff. w/10 yr compressor, sound blanket on compressor, low & high pressure cutouts, and louvered coil guard.0
