checking ground
and I will send you FREE a troubleshooting guide that will walk you through it step by step.
By the way the best ground is the gas valve itself. Use that for ground and test from burner ground on the module to the gas valve ground you should have continuity.
checking ground
I forget how to check for proper ground on furnace ,as I remember check voltage from com on board to furnace cabnet??duhh cant findit inany books.Its been a while
- 50 Industry Classes
