ADS replacement
heatboy
Member Posts: 1,468
.....they were just replacing ADS 6 with a newer version. I have the Wrightsoft version and it definitely has a learning curve. I have trouble with the loop draw, manifold placement and getting the loops to it. I should mention I am pretty dim at times.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=304&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Has anyone
tried the Uponor wright soft version yet?
Uponor has discontinued ADS, and my program only will expire soon.
ADS
Uponor will be releasing the new version of ADS July 27th. You can call Uponor and get a code to keep using the version of ADS you currently have.0 -
Just a Caution
If you use the program as I do and think that the pricing is always up to date as it should be think again. I have lost a good chunk of change and not to happy about it; because I depended on the programming to be up to date with the pricing and to top it off you cant change the prices manually in the database. Now there is going to be another price increase on July 1st. Hope the update comes out before the end of June.
ADS Code
To extend you version use this code WADS6-JDFVG0
- 110 Chimneys & Flues
- 977 Plumbing
- 387 Solar
- 17 Recall Announcements
