Radiant Heat Loss Program
adambuild
adambuild Member Posts: 420
Does heat loss software for radiant differ in that you need less btu/hr because of the mass that is transmitting the heat to the space/people?
  • Ray_13
    Ray_13 Member Posts: 15
    Does anyone know of a radiant heat loss / design program that has warmboard as one of the methods?
    Ray
  • Glenn Sossin_2
    Glenn Sossin_2 Member Posts: 592
    substitue
    I use thin slab concrete setting for Viega's program when figuring warmboard - so far its worked ok.
  • heatlink
    i use healink design suite which has their dry above system, very similar to warmboard.
  • A.J.
    A.J. Member Posts: 257
    radiant program
    Watts Radiant has on.
  • Uni R_3
    Uni R_3 Member Posts: 299
    Mass is just a flywheel.
    it smooths things out at the price or responsiveness.
  • You've actually got a safety factor built in doing that, if you're doing reset water temps/consistent circulation. Not a huge one, but this is a decent band-aid method until software catches up.
