ANyone recognize this combination? (oil burner)
Mike Reavis_2
Member Posts: 295
Found decomissioned in a basement in Charm City.
Might be an old Electrol or Quiet May
but whatever it is, it's a museum piece! Any chance of salvaging it?
the boiler control was a quiet may
where would you put it?0 -
At the shop for now
maybe it would gravitate to the Holohan, Mercurio or Lanthier museums after Gordon and I played with it for a bit.
That's not in a church, is it?
It looks like
the steam system is now hooked up to Trigen, yes? Where in Charm City is it?
is
is this an old low pressure fried oil burner in a vaccum system just
my two cents
joeg0 -
If it's a Quiet May
it's probably an early high-pressure unit. There were some pretty wild designs in the 1920s but I'm not sure the May Oil Burner Co. used anything other than high-pressure.
Boiler
The boiler is a U.S. Radiator, and the burner? WOW. Is it low pressure? We once had a subdivision built in the 40's that had Quiet May warm air furnaces with a standard gun burner. That thing is a real dinosaur.0 -
Can you post a photo of the burner?0
- 120 Geothermal
