slant fin baseboard
Scott M_3
Member Posts: 32
Hi guys, I have a quick question about slant fin fine line 30 baseboard. Im installing some new baseboard that has the return tubing running in the baseboard enclosure. The baseboard has a space that the tubing fits into and slant fin says to support the return tubing with slant fin hanger support wire. Is this just regular wire hanger or do I need to find a slant fin supply that carries this part because I picked up the baseboard at home depot and they dont carry the wire. If it is just regular wire hanger whats the best size to use? Thanks for the help.
You could use:
string, zip-ties, coat hanger "stock," lead-free solder, bailing wire, and even nothing!
Matter of fact, nothing probably works best!
Run the return
on the top of the element, do it all the time no problems.
Mitch S.
baseboard prefrence
Thanks guys0
- 120 Geothermal
