Welbilt air handler - need part
Michael Diack
Member Posts: 3
My customer has at least a 30yr old Welbilt Air Handler. The blower motor belt broke and was removed by a prior tech who told her to replace her entire system. Granted, she needs a new system, however, its not in her budget right now. Can anyone help?
Welbilt Air Handler - Astoria, NY
Model # 6804BD
SN# 7-11048
Has a 1/2 HP AO Smith Motor C48J4C11
The blower wheel is imprinted with BROWNING 4X81
Thanks everyone!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=505&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Model # 6804BD
SN# 7-11048
Thanks everyone!
belr size
> Can anyone help?
> Astoria, NY Model # 6804BD SN# 7-11048 Has a
> 1/2 HP AO Smith Motor C48J4C11 The blower wheel
> Thanks
> everyone!
> _A
> 505&Step=30"_To Learn More About This
> "Find A Professional"_/A_
Use the formula of: drive pulley diameter X 1/2 of pi (3.14) plus the driven pulley X 1/2 of pi, plus 2 times the center to center distance of the shafts, added together will give the belt length. Use where the outer edge of the belt rides on both pulleys. Determine the belt width, A belts 1/2" B belts 5/8"
Good luck, Wayne0 -
what are you looking for? A belt? YOu should be able to get a replacement belt at any supply house. Take a string and put on pulleys to get length and then measure width of pulley and depth to find out if itis a a, b, bx, etc. Also you could use a segmented belt and make your own.0
