Demented Divicon
joe_66
joe_66 Member Posts: 30
Sounds like Gary has you covered but (401)732-0667 will take care of any future problems.Viessmann techs have been awsome for me.
  • Brian
    Brian Member Posts: 285
    Demented Divicon
    I've got a Divicon on a VB-22 that is running backwards.After pulling my hair out(what little I have)tring to get the actuator to work I pulled it off to manually set the valve.I discovered that when I pointed it towards hot I got cold and vice versa.There's no way to pipe it wrong so I'm going back tommorrow to see if I pull the handle off and give it a 180 turn if that will solve the problem.Have any of you guys seen this before and how did you solve it?
    Thanks, Dobber
  • Dip Switch set wrong.
    Remove the cover and change the dip switch settings. It's in the installation manual that comes with the MVA. This will change the rotation of the motor.
    Wallace Radiant Design
