Remote sensor for thermostat - averaging?..............(Starch)
John Starcher_4
John Starcher_4 Member Posts: 794
...to install a thermostat to control air conditioning for a commercial application. I would like to have a remote sensor, and install the stat in a closet.
Does anyone make a stat that can have three sensors wired to 'average' the temperature that the stat sees?
Starch
  • John Starcher_4
    Yes.
    Just talked to the Honeywell rep.
    It can be done with the focus pro 8000, but needs 4 sensors to work properly.
  • Jack
    Jack Member Posts: 1,050
    You could use the
    Braeburn 5300/5400. You can use 1, 4 or 9 sensors, not 3. I'm not sure of the electronics on this but it has to do with the power wave signal. Check them out at www.braeburnonline.com
  • Kal Row
    Kal Row Member Posts: 1,520
    as the sensors are most likely thermistors...
    you can series-parallel as many of them as you like as long at the total resistance remains the same - it goes like this
    1 alone
    2 rows of 2 sensors in each row
    3 rows of 3
    4 rows of 4
    5 rows of 5 "eh-tzet-te-rah..eh-tzet-te-rah.." (Yule Brenner in "the king and i")
    when you put two in parallel you half the resistance so you have to double up each in series - with that method you can fill a whole house with sensors and get the avg temp - it a best input to a modern boiler controller's "room sensor" input
    However don’t forget the resistance of all that connecting wire, with so many sensors it could have a effect on the temp sensed
    if you really need an intelligent demand, I would go with the InnovexTechnologies iWorx, a simple 2 wire LON networked controller and temp sensors and boiler controls – and you can operate it all from the internet, and you can bias every sensor +-255, so you bias a sensor on or off completely or adjust for a bad sensor location with a small bias, for course there are the Honeywell and the tekmar tn4 systems as well – but the Innovex comes out a lot cheaper per node – I put it and new boiler into a school and they saved 18,000 on fuel last year, and with the price increase, this year was an even bigger saving – I even have their window air conditioners on the iWorx – via a lighting control module and relays that runs with both a schedule and a schedule override to off via the iWrox alarm module when the outside temp hits 65 – it’s a nice, easy, and inexpensive system to know about, as you can no longer get a non-“Green” school or municipality contract
    www.InnovexTechnologies.com – a really great company to do business with – and since you can put the controller on the net with the built in Ethernet port – they can help you troubleshoot by remote control
