ford products corporation
Bob Bona_4
Member Posts: 2,080
went out around 1992-1993. Seems everyone had the oil fired water heaters around here in CT.
Memory is fuzzy, but seems that Carlin had some sort of involvement in the brand.
Looks like time for a new boiler!
FORD PRODUCTS CORPOATION
I recently went to a job for a leaking boiler and found the boiler hot water plate was leaking. the boiler is made by ford products corporation, i cant find anything on the web to get parts or a history of this company. any ideas?0 -
> CT.
> Looks
i figured that . i did see a beckett burner on the boile ...who knows it probaly put in after .
thanks again0 -
thanks again0 -
Ever hot
Ever-hot Therma-flo in Watertown Mass will do custom work they might be able to help you.0 -
If it is
If it is a dry base boiler given the age of Ford units still running it is definately time to replace it.
Leo0
- 87K THE MAIN WALL
- 111 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
