how's a diverter valve work?
Stacie_2
Stacie_2 Member Posts: 3
Er... possibly... the boiler is a Sime Combi boiler.
  • Stacie_2
    A repairman came over to assess our boiler which has not been giving out hot water but has been heating our place. This was five days ago. He hasn't fixed anything yet though he did fiddle around with it a bit.
    He told us the diverter valve needed to be replaced. This morning the boiler totally stopped firing up when even the heating was on. Would this still be the diverter valve or will he just come back and now say we need a new boiler.
    Many thanks in advance!
  • ALH_4
    ALH_4 Member Posts: 1,790
    Diverting what?
    People call a lot of things by a lot of names. It's hard to say without more information. What kind of boiler is this? Is there any possibility you could post some digital photos of the boiler, piping, and the valve?
  • JJ_4
    JJ_4 Member Posts: 146
    Diverter valve
    This is a standard term. Remember "one inta, two outa" is a diverter valve application and "two inta, one outa" is a mixing valve application. In other words, are you mixing two sources into one or diverting one into two? While many 3 way valves can be piped for either application, some (barber-coleman for example)are ported specifically for either mixing or diverting.
  • Stacie_2
    thanks
    Thanks for the info. I'll try to get some photos up, but at the moment I can't get that to work either :)
  • bob young
    bob young Member Posts: 2,177
    slang
    HE might be refering to a zone valve. not all repairmen are schooled in correct technical terminology.
  • Andrew Hagen_2
    Andrew Hagen_2 Member Posts: 236
    Combi
    I'm guessing, but I believe the repairman is referring to a valve inside the boiler that diverts the flow from the heating system through the internal Combi heat exchanger for domestic hot water production. The diverter valve lets you use one pump for both heating and hot water production.
  • Tom Hopkins
    Tom Hopkins Member Posts: 554
    Sime combi boilers are a UK manufacturer.
    If the boiler is producing C/H when there is a hot water demand it usually means the diverter valve is passing which is within the boiler casing.
    I would wait and see what he quotes for the diverter valve changing. It is a possability this will solve the problem you are having now.
  • Tom Hopkins
    Sorry dont know how that happened i'm not Tombig.
    Andy(UK)
  • Tom Hopkins
    Found this thread on another Forum, It may help.
    http://www.diynot.com/forums/viewtopic.php?p=113538#113538
    Andy
