Boiler Roar
Terry
Terry Member Posts: 186
My Money is on dirt.
Dirt or scale cooked onto the tubes will make em howl/roar.
Age of boiler since last good cleaning???
EIN
  • RobLC
    RobLC Member Posts: 93
    Boiler Roar
    Our boiler roars. But even louder when the tech from Keyspan opens the boiler door while it's running.
    Kepspan tech says that's fine. Does a roaring boiler
    sound like it could be wasting fuel?
    If so, how to correct?
    And how do we contact the professional in the Bay Ridge, Brooklyn, New York area.
    Many thanks for the help.
  • Bob_67
    Bob_67 Member Posts: 4
    roaring
    Is the boiler gas or oil was it converetd,and did they do a efficency test smoke stack temp ,co 2.also some modern boilers that dont have a target wall or blanket in the bottom of the combustion chamber will have some noise in the flue.hope this helps
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,712
    Find a Pro
    Just type your Zip code into the Find a Pro section (on the navigation bar) and read what they all have to say. Their contact numbers are in their ads.
    Retired and loving it.
