cold radiator inlet pipe cold all other radiators ok
william_5
Member Posts: 62
we need more info did you have heat in it before, what is the boiler psi at, hade there been any remodling to the system or room? what kind of rad free standing or in the wall?
cold radiator
one of my radiators is cold the inlet pipe is also cold, all others or working. i have tried bleading it with no joy.its a combi boiler.0 -
Is......
....the shut off valve open ?0 -
hi thanks for your reply, it is a wall mounted radiator, this was our warmest and best heated radiator in the house, now it gives absolutely nothing, there is no warm area on the radiator at all.dont know boiler psi, but no one has touched the boiler. would appreciate if you could help me thank you0 -
thanks for your reply yeh its open. this wall mounted radiator used to be our warmest and best radiator in the house, now we have nothing from it there is not one warm spot on the radiator. would appreciate if you could help me with this.0 -
I'd be suspicious of the air valve on the cold rad. You might remove it and see if it's open. Also you can see if there is steam to the rad while the vent valve is removed. Be careful though and be ready to shut off the inlet valve before you have a new sauna.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
